SparkieBoat
Thread starter- Joined
- Aug 17, 2009
- 3,643
I got a friends E70TLEOR that ran hot, we resurfaced the head and new gasket, compression is 85, 105, 120...after cranking motor (which cranks and idles great) compression read 129, 120, 120... ran motor and it is very weak. I assume the rings need to be changed out. The pistons looked ok to me..and the cylinder walls looked good as well.
Can I just change out the piston rings??
I am trying to limit the amount of work and $$$ spent on this project as this is on a twin motor boat...and my friend will be up-powering next year. so if it is going to run into over $400-500 bucks, he will just go ahead and look at a pair of larger motors.
