1995 70hp evinrude temp question
Bob427
my 95 70hp evinrude seems to run around 160 degrees when i idle down the river to the lake about a mile trip
as soon as i open it up the temp drops to around 120 degrees
and if i idle around alittle bit back up to 160 degrees
and right know surface temp of the lake is about 65 degrees
now it runs great
last year i changed out the entire water pump housing and impeller because the kit came with all the updated cooling changes
and i changed the termostat too
last season i really didn't do much idling because i changed lakes where i fish now the idle time is much greater
so really never noticed the long term idle temperature
should i be alarmed by the idle temp or do you guys think its ok
thanks Bob
JohnWI
Re: 1995 70hp evinrude temp question
TTT....I'm also interested in knowing
durban
i wouldn't worry about it , as the motor idles the impeller turns at the idling rpm , when you throttle up the rpm increases the impeller turns faster & pumps more water to the motor , the volume increases more water enters the block that increase in pressure of water is then released through the poppet values , so you have more cold water coming into the motor & being released through the poppet valve thus the motor temp will drop slightly
WernerF
As far as I know it's supposed to be this way. At higher rpms the increasing water pressure lifts up the thermostat off its seat thus providing additional cooling.
boobie
Sounds normal to me. Run it !
Bob427
thanks for the info
perch here i come!
