FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
My 1995 90 hp force power tilt and trim motor is running slow. Is this just because the motor itself is going out or do i need to replace the hydralic fluid?
Re: 1995 90 hp Force, my power tilt and trim motor running slow.
The three ram system is supposed designed to trim slow and tilt fast. The single ram system should be the same speed throughout.
If the fluid is low then the system will not lift all the way. As long as the system is moving then the motor should run normally. If it runs slowly then it is either a bad connection or a bad motor.
