I posted earlier about this motor starting up running briefly then shutting down and that was solved with a fuel feed pipe repair.
However a new problem (seemingly) occurs. Poor idle, runs under load for a while then dies out.
I've replaced the fuel filter, checked all hoses and everything looks in order.
When it dies out, if I manually squeeze the primer bulb it will often fire back up. Maybe the fuel pump is failing or there is restricted flow leading to it.
It'll run for 15 or more minutes at slow speed before stalling out.
Any tips as to what to look for are appreciated! Thanks.
Jamie
Jamie
![IMG_0164[1].jpg IMG_0164[1].jpg](https://forums.iboats.com/data/attachments/175/175946-3fa94733d363e0c127e45eb533f36fcf.jpg)
