1995 Bayliner sportjet
Status
Not open for further replies.
fire tech
I have a 1995 Bayliner sportjet with a 90hp mercury. I've recently replaced the switchbox,spark plugs,rebuilt the carbs,and set the timing. Engine sounds good and revs up good, but it's slow out of the hole. It's only a 14' foot boat very lightweight. With two people it takes a while to plane with three forget it. When it does plane it runs about 30mph. It just feels dead in the water. If anyone can help me I would appreciate it.
hondon
Re: 1995 Bayliner sportjet
This was not Mercs proudests moment.If you are certain that all is as it should be ,and do'nt overlook the jet pump,this could be all all you've got.Those 90s and 120s for some reason did not deliver,[FORCE?],but they did set the stage for the very fun products out there now.
Mercury140-I6
Which model do you have, the Jazz or the Reflex? I know that the Reflex would top out at about 33 - 35 with one, low 30's with 2 and with 3, the third person has to stand up and lean over the windshield until it's on plane. The Force powerheads really don't perform like the Merc powerheads do. I have never been in or driven a Jazz, so I can't really comment on those, but I can't believe that they are that different.<br /><br />Craig
fire tech
This a 90hp mercury power head and a Bayliner Reflex.<br />Is there anyway to improve the take off power?<br />Would trim tabs help?<br />Is it a gas gusler?
fire tech
will any other power head mount on this jet drive<br />(as in other brand)
Mercury140-I6
Fire Tech. I know that it says 90hp Mercury SportJet, but it really is a Force outboard block. If you are able to get the displacement of your motor and comapre it to a Mercury 90, they are different, then compare it with a Force 90, they are the same. A friend of mine had the Reflex with the 90 when I had a 140 Merc on my Glastron. His tank was 2 gallons bigger than mine and everytime we went to get fuel, his took more than mine did and I was doing all of the towing of skiers and tubes, and could still walk away at anytime I felt like it.<br /><br />In the later years of the Jazz, they did upgrade to a 120 Mercury Sportjet (Force 120 powerhead) Might be a thought.<br /><br />Craig
funpilot
fire tech,<br />I have a Sugar Sand Mirage with a sport jet 120. The 120 jet pump (and subsequent jet pump drives from Mercury) are geared differently than your 90 jet pump. Also, you have a crankshaft end with 13 splines, and a specific bolt pattern, so if it isn't a sport jet, it isn't bolting in. The subsequent jet pumps are larger as well. In my opinion you are pretty much stuck with your engine, but that isn't all bad as the engines are very strong, the weak point being the electronics. So, I guess your best option is to assure that you are developing all the power you deserve, so check your compression, timing and carbs.<br /><br />Then take a look at your ride plate. Make sure it is straight with the boat, flush against the bottom, and no screws are missing. Look at the Gasket between the rideplate and the hull and make sure that looks good. Peak up underneath and see if the impeller is in good shape with smooth edges and assure that the wear ring (the circular fence the impeller spins in) doesn't have too much of a gap. A good gap is .010 inches, but I've heard of some that have worn to about .032.<br /><br />Finally make sure your reverse bucket completely clears the jet pump nozzle when you are in fwd 'gear'.<br /><br />The sport jet does suck gas, and since it isn't a propeller outboard the equivalent power is about 2/3 of what an outboard would do. That means basically it should act like a 60hp. The sport jets also are a bit slow to get out of the hole, but once on plane, are fun to drive, and since the impeller never reverses direction, you can go from forward to reverse without a pause for some spectacular water fun.<br /><br />good luck
kenimpzoom
Yep, welcome to the slow Sport Jet 90. I have the same thing. With 4 people in the boat, it takes forever to plane and about 25 MPH top speed. With only myself I can get 33-34 MPH.<br /><br />Smart Tabs will help a lot on planeing faster, but it wont help on MPH.<br /><br />Ken
Jdeagro
iboats.com Partner
Kenimpzoom;<br /><br />If you have not picked up a few MPH then I would reduce the pressure (at the plate bracket) on the Smart Tabs. If this does not give you more speed then call me, <br />John 800-233-0194.
WIMUSKY
Welcome to the forum solarbuz11. This topic is 14yrs old. Please copy your info and paste it into your own Topic. Also, browse thru the forum rules.... Thx
WIMUSKY
Status
