floatfan
Thread starter- Joined
- Feb 28, 2011
- 184
Had an issue with the trim, would go up but not down. Switched the wires on the relays, and discovered that is the issue. How do I change the relays though? Everything in the service manual and here that I see claims that these are easy change plug relays, but I don't see it. They look to be bolted together, with a series of 3 bolts (1 on top, 1 between the 2 relays, and 1 at the bottom).
2nd question. Battery is fully charged, but when I turn the key, nothing happens. Starter?
