1995 force 120hp oil change
rzkas
hi and how are you? i am want to change the oil on my boat. the lower end of the engine has screws. one say vent, the second one say oil level and the third one has nothing. i want to know what two screws i should remove to change the oil and add in oil. pls tell me and show me where i can locate the oil drainage screw. thanks
I HAVE A 1995 FORCE 120HP
bentle
Re: 1995 force 120hp oil change
Oil drain screw should be on the very bottom of gearcase. The little screw that says nothing means don't touch that one or oops!!
1. Remove both screws that say vent and level.
2. Remove drain screw on very bottom and let drain. Milky oil indicates water in oil.
3. After drained put the drain screw back in place on very bottom.
4. Fill with new gear oil in the oil level side, make sure vent screw is still removed.
5. As soon as oil starts to come out of the vent hole then replace screws.
Its also a good idea to replace the little nylon washer or it may leak.
