hi, ..got this motor , checked the compression , came out fine, 130psi per cylinder, put it in my Bayliner , and it was running rough , did the carbs and FP and still the same , it was hard to crank the motor and the starter getting hot, pull the plugs and find water in the plugs, pull the head, and find a lot of moisture in the cylinders, specially #3, inspected the head gasket , and looks fine to me , actually looks like if it was changed no long ago, doesn't looks like a 18years old gasket. checked the water jacket and found that Force use just silicone,..now my question... is there any other place or part than can cause this problem?..thanks
