Re: 1995 Force 120HP
basically, you pump the gearcase with 10-12 psi of air pressure and wait. If air leaks out then you figure out where the leak is and fix it. don't overinfllate your gearcase or you'll blow out good seals. harbor freight sells a pressure tester for $15. I would expect northern tools to have something too. you can rig up an acceptable alternate with foot pump (that has built in pressure gauge) and plumbing valve. you could probably even turn a blood pressure ball pump into one if you wanted.<br /><br />seized bolts are the worst. they can turn a 10 minute job into a 10 hour job in the twist of a single bolt. It's not force. It's anywhere that stainless and aluminum come into contact with a conductor (such as salt water, acid rain, or polutted lakes). If you ran your boat in distilled water and stored it inside, then I doubt you'd ever see it.
