1995 force 40 hp RPMs?
jrtax
I have a 1648 G3 with a 40hp force with tilt and trim. The prop has an 18" pitch. I installed a tach and im not sure if its adjusted right to show the accurate RPMs. Is there any way i can find out about what RPMs it should be running at WOT to check it with my tach or is there any way i tell if the tach is giving the correct reading. Thankds alot for your help
anple
Re: 1995 force 40 hp RPMs?
Motor Specs
Manufacturer: Force
Year: 1995
Horsepower: 40.0
Cylinders: 2
Type: 2 stroke
Gear Ratio: 2.00:1
Min WOT RPM: 4750
Max WOT RPM: 5250
Spline Count: 13
Drive Type:
Justinde
Thank you Lieutenant Commander Data:D:D:D
jrtax
Thanks alot. There is an adjustment on the back that you can turn with a screw driver that causes the RPM reading to vary. When i installed it i accidently turned it all the way to the left. Is there a certin way it should be adjusted? Thanks Alot
