1995 Force 70hp water pump seals
Force39
Hi, I've included pix of my 1995 Force 70hp water pump parts. Photo showing seals, gaskets,etc has the removed parts on top and the seal kit I bought on the bottom (Sierra 18-2635). Photo of the driveshaft shows what was under the removed parts from top of parts photo. Photo of diagram shows what should be involved in this rebuild. I want to make sure I put everything back together correctly, but what came out, what should be and what is in the seal kit are all a bit different. Please help. Thanks, John
tommarvin
Ensign
Hi John, You got this, Don't forget the keyway, looking down like pic #2driveshaft turns clockwise, make sure the impeller fins are oriented the correct way, l
marine grease the plate below impeller ,and the housing, you may as well buy a inch pound torque wrench,you are going to need it.I always marine grease all threads. We have the Chrysler Outboard Service Manuel for 105, 115,125,&140 HP outboard motors,if anybody needs to borrow it. A thought search removing snapped bolts, so your ready, cobalt drill bits
tommarvin
Ensign
Just to be safe, I would take the thermostat out, put in a pan of cold water and heat it up slowly, what temp does it open , ours open at 115 F,and over heat buzzer is 180 F , I'm going to test that if it ever stops raining, battery charged key on slowly heat up water, just hold a little bit of the end under water, what temp does it buzz ?
