Hello All,
Motor is a 1995 Force 90 Hp 3 cylinder S/N 0E104323.
Customer brought it to me after letting it sit for 2 years without being prepared for storage. It was running but sounded like a chainsaw at wide open throttle.
I slowed it down to a near normal idle. It then stalled out,
I checked the DVA readings for the Stator,trigger and output to the coils. I found the trigger and output from switch box to coil to be low, so I replaced both.
Still no start. Checked the fuel going to carbs and found it was nearly pure two cycle oil. All the gas had evaporated away from sitting. Replaced fuel filter, plugs,
and rebuilt carbs. Pumped primer bulb till fresh fuel came out at carbs.
Noticed starter shaft was bent. Replaced starter. No start. Noticed new starter shaft is bent already. All starter mounting bolts are tight. Lower starter mounting bracket in place and tight. Owner tells me he had replaced a starter due to a bent shaft for a total of three starters.
Compression is 120, 116 , 122 on cylinders.
No evidence of water in cylinders.
What would be causing this motor to eat starters?
Thanks
rcb130
Thanks
rcb130
