hello all,
New to the boards here. So maybe someone can shed some light on my problems. First off i noticed at slow speed my engine starting to run rough and was going though a no wake zone for about 30 minutes. Then after the final marker i throttled up and it ran great for about 1 minute and then I felt the power start to slip away till it got so low it stalled out. I tried to restart but wouldn't. I then put the engine in neutral and it started and would run at any rpms. once i dropped it into drive it shut-off, then after another neutal and drive it started to move. then after a 20 minute full throttle i went to drop it down to about a quauter and it lost power again and the whole thing started again. I looked at the plugs when I got back and they were really wet and there was one plug wire a little loose but still connected, also how far does the throttle control need to be moved before the throttle in the engine begins to move I noticed I have to move the throttle control about 2" before and change happens in the motor throttle. thanks for any help
