vipertblck
Thread starter- Joined
- Sep 25, 2012
- 205
Re: 1995 four winns horizon 190-GOOD/BAD
The outdrive only says "OMC COBRA" on it, nothing about king cobra, or cobra SX, so i'm not sure what thats all about or what drive it even is. i got some numbers off the back ill call a volvo penta dealer and see if they can cross reference maybe just to know if i can in fact get parts for this if i did purchase the boat.
Also another poster said something about manifolds being impossible to get, i've seen in other forums folks talk about manifolds, are exhaust manifolds a frequently replaced items on boats? I come from the automotive world and replacing manifolds is rare in my experience, is something different with marine engines that they require manifold replacement?
Maybe I can clarify a bit. In the mid-late '90's OMC entered into a joint venture with Volvo-Penta. I believe that the Cobra SX drive was in fact created by OMC. Volvo sold them too under their own name,as V-P SX drives. When OMC went belly up Volvo sold them exclusively. Sooo, if you find an OMC Cobra SX, it's also a V-P SX. That applies ONLY to 'SX' type drives. An OMC King Cobra drive is a 'run away from it'.
My 1997 Four Winns is a conglomeration of V-P and OMC name tags- the drives are tagged as V-P SX, the engines are OMC Cobra 4.3's, and my throttle/shift control is labeled with the OMC brand. Drive and transom assembly serial numbers are V-P, engine MODEL is V-P, engine serial numbers are OMC... but it's all the same stuff and I buy parts through V-P suppliers.
Last year I needed a fuel pump. Called the local V-P parts guy. He looked and said he had 2 of the same- one had a V-P part number, the other OMC. He told me the OMC was about $10.00 cheaper so he'd sell me that one. When I arrived and he pulled it off the shelf, the OMC part was in a V-P box!
The kicker with this particular boat is the engine- it's Ford and you don't want one.
