Re: 1995 johnson 115 Ocean runner Alarm when key is turned to on position w/o motor o
My problem is a little different then the original post. I turn the key on and the alarm sounds just for a moment and all the lights come on one at a time while the system is going through the checks then they all go off. Start the engine and it runs for a few minutes then the overheat light comes on and alarm sounds for a few seconds then goes of but the light stays on. I've pulled and checked the t stats on pot of water they open and close fine, pulled the pop off valve and found that the seat was installed backward turned it around and put it back in. Checked for chaffed wires that may be grounding and loose connections all seem good. The water is getting to the t stats and the pop off valve. The engine is not overheating I checked it with a temp gun, when the light and alarm goes off the temp on both heads was 109deg. I'm thinking it may be in the temp swithches. Any other ideas?
