1995 Johnson 130 cooling system
MC 29
So I am baffled. Had no water running through the engine. Removed lower unit water pump seemed fine tested by hooking up a drill to the shaft pumps fine ( although a lot of water though the weep hole on the cover is that normal ? )
Attached a garden hose to the copper water pipe and removed thermostats finally got water through the engine but it took about a minute for it to come out the stats and telltail. That seemed like a long time. Any suggestions
Thanks Mike
