1995 Johnson 150 Oceanrunner starting problem, no spark.
nomisx98
Hello Everyone,
Let me start by saying this is a great site and it has helped me out alot in the past. I am having problems starting up my motor and was wondering if some of you fellas could give me some pointers. I have a 1995 Johnson 150hp Oceanrunner, the motor always started up right away and ran great. I have been out of town and have not started the boat up in a 3 months and now when I try to start her it won't start. I have plenty of fuel and oil. The starter works and it appears it is turning the flywheel pretty good. But when I did a spark test I knoticed I was not getting a spark. What I did was pulled a spark plug and stuck it back in the wire and held it near the engine block to see if I get a spark when I crank the motor. Tried couple plugs and both had no spark. Can anyone give me some input on this? Would a weak battery cause no spark at all? Thanks again!
tashasdaddy
Re: 1995 Johnson 150 Oceanrunner starting problem, no spark.
welcome to iboats
it is time to trouble shoot properly. using a spark tester, record spark on all cylinders. you only have one power pack, if no spark could be power pack, BUT it could also be a bad ignition switch, a shorted kill wire (black with yellow tracer). you can unplug the big red plug, and use a remote starter switch to jump the starter solenoid, and recheck spark. also read this http://www.boatpartstore.com/page35.asp
CatTwentyTwo
There is a minimum RPM that the starter has to crank the motor at before the ignition system will begin to operate. It might be worth putting a charger on your battery for awhile and see if that helps.
Chris1956
Honorary Supreme Mariner
Does that motor have a kill switch and lanyard, separate from the ign switch? A lot of them do, and if that is tripped, you will get no spark.
nomisx98
Yes it does, but would that still allow power to the starter from the ignition?
nomisx98
welcome to iboats
I just purchased a manual from the site, so I can figure out what is where that you have described. Thank you for your help will keep you posted in my progress.
nomisx98
I will be looking into purchasing a charger over the weekend. I'm long over due to purchase one anyway. Will give it a try, thank you!
Chris1956
If the kill switch is tripped, the motor will crank but not start.
nomisx98
Update on motor, I fully charged the batteries and the motor started up. It ran for roughly 15 minutes and then it shut off on its own. I tried to start the motor again and no luck. A few times the motor sounded like it was trying to kick over but nothing. Could it be the motor is flooded? Any suggestions?
Chris1956
I would start by verifying that you have spark to each cylinder. If not, find out why. It could be as simple as a bad/waterlogged kill switch or bad ign switch.
