1995 Johnson 150 shuts down after 5 minutes of full throttle
Clint W
My motor has always seemed to starve at the top end but the last 3 outings, I get on a plane and am cruising along for about 5 minutes and I feel a bump or two and then it just shuts off. The first two times, it took over 30 minutes before it would start again and then it seemed to run okay (not great but okay) for the rest of the day. Last outing, it started up after 10 minutes.
I do have spark on all cylinders and compression. I am suspecting the power pack may be intermittent. I have checked all of the wiring for chafing and connections are good.
Can any of you help a brother? How can I check this power pack?
Possible overheat with ---S.L.O.W.---kicking in.----Do you install a new impeller every 5 years ?----Warped carburetor bowls ?----Possible issue with shift interrupt switch ?----Remember , I can not see , hear or touch your motor.
Clint W
Thanks for chiming in racerone. I don't think it is overheating because it will run the rest of the day after that initial period of shutdown but I can definitely look into that. I haven't installed a new impeller but the stream is strong out of the back port. Carbs are all straight and were recently cleaned up 2 years ago. Thanks for the guidance and tips for sure. I am sure it will take a bit of troubleshooting on this one, especially since it is intermittent.
Crosbyman
carbs are never as clean once they are reinstalled and passing fuel for 30 seconds.. one never knows more so after 2 years .jmho
Run with a timing light , one cylinder at a time.----Observe the flashing light when motor acts up.
Clint W
Could be possible optical eye failing
I was wondering about the optical sensor. I did a bunch of troubleshooting today and pretty much boiled it down to two things, the optical sensor or the power pack. That is, if the spark plug change doesn't make a difference. I can't really see the optical sensor though cuz I can't get the cover to come off (one that has the data on it) because it is pretty stuck and I don't wanna break it.
I am not new to boats but am semi-new to this one since I inherited it from my dad when he passed in 2020. He did swap the spark plugs for NGKs and they are a direct replacement according to cross reference data but they do not appear to be exactly like the actual Champion plugs which I just bought and installed. I am gonna take it out Tuesday and see how it does. It runs really well with the hose but that doesn't mean much since it seemed to do the same before. Worst thing is, I can't replicate this failure with a hose cuz it seems to happen when the motor has run about 5 minutes at full throttle.
Crosbyman
fwiw... hre is an opinion from CHAT GPT
Q: what causes a 1995 Johnson 150 shuts down after 5 minutes of full throttle
ChatGPT said :​
Good question — a 1995 Johnson 150 (2-stroke, V6, carbureted or EFI depending on model) shutting down after about 5 minutes at full throttle is a classic symptom of a few possible issues related to fuel delivery, heat, or ignition protection systems.
Let’s go through the most common causes, ranked by likelihood 👇
🔧 1. Fuel Starvation (most common)​
At wide-open throttle (WOT), fuel demand is at maximum. If the engine runs fine for a few minutes then dies or bogs and restarts after a short wait, this usually points to restricted or insufficient fuel flow.
Check these:
  • 🧽 Clogged fuel filter / water separator — replace or inspect for debris or water.
  • ⛽ Anti-siphon valve at the fuel tank outlet — can restrict flow under high demand.
  • 🧴 Fuel line collapsing internally (especially if ethanol has softened old hoses).
  • 🔄 Vapor lock — caused by heat soaking in lines or VST (if EFI version).
  • 💨 Fuel pump diaphragm — weak or leaking, can’t maintain volume at WOT.
  • 🧊 Fuel tank vent — closed or obstructed; test by running with fuel cap slightly loose.
🧠 Symptom clue:
If the engine restarts after idling for a bit, fuel starvation is almost certain.
🔥 2. Overheat or S.L.O.W. Mode​
Johnson/Evinrude motors have a S.L.O.W. (Speed Limiting Overheat Warning) system that limits RPM or can trigger shutdown if:
  • The engine temperature sensor trips,
  • Or oil/fuel sensors detect a problem.
Check:
  • Proper tell-tale water flow (strong and steady stream).
  • Thermostats and pressure relief valve condition.
  • Overheat horn sounding before shutdown?
  • Use an infrared thermometer at the heads — shouldn’t exceed ~160–170°F.
🧠 Symptom clue:
If you can restart right away but RPMs are limited (~2500), it’s in S.L.O.W. mode, not a total stall.
⚡ 3. Ignition Breakdown (heat-related)​
After several minutes at WOT, ignition components can fail when hot.
Suspect:
  • Power pack (CDI) failing when hot.
  • Coils or stator with heat-related internal shorts.
  • Timer base wiring with cracked insulation.
🧪 Test idea:
Run it until shutdown, then check for spark immediately.
If no spark → ignition issue.
If spark present → look back to fuel.
💧 4. Fuel Tank Pickup or Debris​
Sometimes debris in the tank floats up and blocks the pickup screen under high suction, then drops away when suction stops — giving you a “runs fine again after a minute” pattern.
🧰 Diagnostic Steps​
  1. Run with a portable tank (clean 50:1 mix) directly to the motor → isolates boat fuel system.
  2. Monitor spark immediately after shutdown.
  3. Check fuel bulb — is it collapsed or empty? (means restriction or vent issue)
  4. Check for overheat horn or RPM limiting.
  5. Inspect plugs — if they look lean (white) = fuel problem; oily or wet = ignition.
If you tell me:
  • Whether it’s carbureted or EFI,
  • Whether it restarts right away,
  • And if there’s a warning horn or light,
…I can narrow it down to 1–2 exact components to test first.
Would you like to give me those details so I can pinpoint the cause more exactly?
REPLY​
Carbed engine .... after a period of 10-30 min it will run ok all day .Problem is hard to replicate unless run wot for 5 minutes
ChatGPT said :​
Perfect — that detail helps a lot.
So:
  • 1995 Johnson 150 carbureted,
  • Shuts down (dies completely) after 5 min at full throttle,
  • Then after cooling or resting 10–30 minutes, runs fine the rest of the day,
  • And it’s hard to reproduce unless you hold WOT for a sustained period.
That pattern points to something that fails with heat or fuel draw, but then recovers once cooled or refilled.
Let’s break it down now that we know it’s carbureted 👇
🔍 MOST LIKELY CAUSES (ranked)​
1️⃣ Fuel Starvation — Main Culprit​
This is still #1 suspect on a carbed Johnson V6.
At full throttle, the engine drains the carb bowls quickly; if the fuel pump or delivery system can’t keep up, it runs lean and dies.
After it sits, the bowls refill — and it’s fine again.
Check these first:
  • Primer bulb condition:
    • When it dies, immediately squeeze it — if it’s collapsed → tank vent or line restriction.
    • If it’s empty/soft → pump not keeping up or line restriction upstream.
  • Fuel tank vent:
    • Try running with the fuel cap slightly loose next time.
    • If problem disappears, the vent is blocked.
  • Pulse fuel pump:
    • If diaphragm is weak or leaking air, it’ll starve under sustained load.
    • Rebuild kits are cheap (<$30) and often solve this issue.
  • Anti-siphon valve (at tank outlet):
    • Common restriction — replace or temporarily bypass for test.
  • Fuel pickup tube or debris in tank:
    • A floating flake or plastic film can intermittently block the pickup during heavy suction, then fall away.
🧠 Hint: Since it runs fine for the rest of the day afterward, that’s consistent with air in fuel system working itself out or vapor lock dissipating.
2️⃣ Vapor Lock / Heat Soak in Fuel Lines​
After long WOT, the fuel pump and lines near the powerhead can get hot.
If there’s ethanol fuel, vapor bubbles can form → loss of prime → stall.
After sitting 10–30 min, fuel recondenses, and engine restarts fine.
Fix / Test ideas:
  • Route fuel lines away from exhaust cover.
  • Use ethanol-free gas if available.
  • Ensure fuel pump check valves are sealing tightly.
3️⃣ Power Pack or Stator Heat Failure​
A bit less likely because the engine runs fine all day afterward, but worth mentioning.
A stator or power pack that fails when hot can cause a complete shutdown (no spark), then recover after cooling.
Test:
  • When it stalls, check for spark immediately on one plug.
    • No spark = ignition side issue.
    • Spark present = fuel side.
If it’s ignition heat failure, it will usually recur more quickly each time, not disappear for the rest of the day.
4️⃣ Fuel Bowl Venting​
Each carburetor has a bowl vent — if one is clogged, you get vacuum lock in the bowl, limiting fuel refill at high demand. After shutdown, the bowl slowly equalizes, and all’s fine again.
Clean all carb vent passages with compressed air.
🧰 PRACTICAL TEST PLAN​
Here’s how I’d troubleshoot it systematically:
  1. Next time it stalls,
    • Pump primer bulb:
      • If motor restarts instantly → fuel starvation confirmed.
    • Check spark right away if no restart.
  2. Run on a portable fuel tank with short new hose (bypasses boat’s tank & lines).
    • If problem disappears → restriction or vent issue in boat fuel system.
  3. Rebuild or replace fuel pump (it’s cheap and a frequent culprit).
  4. Inspect carb bowls and vents for debris or varnish.
  5. Use fresh, non-ethanol fuel and check fuel filter for air bubbles.
If I had to bet:
💡 It’s either a weak mechanical fuel pump or a restricted fuel vent/anti-siphon valve causing starvation at WOT.
Clint W
ChatGPT said :​
Check these:
🧠 Symptom clue:
Check:
🧠 Symptom clue:
Suspect:
🧪 Test idea:
🧰 Diagnostic Steps​
If you tell me:
REPLY​
ChatGPT said :​
So:
Check these first:
  • Fuel tank vent:
  • Pulse fuel pump:
  • Anti-siphon valve(at tank outlet):
Fix / Test ideas:
Test:
    • Pump primer bulb:
  2. Run on a portable fuel tankwith short new hose (bypasses boat’s tank & lines).
If I had to bet:
Crosbyman, thanks for sharing all of this.
Crosbyman
I am not a AI guru but this free service from CHAT GPT is amazing (not always 100% correct as it is learning) but it aswers questions on ANY subject even for OB bugs like yours !!
it even found me a back door to AMAZON customer service to get me a full rebate I could not extract from the front door maze of looped around questions.... Amazon CS even told me to keep my 100 AAA batteries ordered by mistake instead of AA size :)
It gave me tons of info on servicing a 2009 Hunday ACCENT to keep it going
(freebie with NO RUST whatsoever !!)
Clint W
I use it a lot and did research this issue through it. We have one for the gubmint called NIPRGpt and it might have written my annual appraisal haha. What I really need is the schematic for the power pack so I can check it with a meter.
Crosbyman
Clint W
something here may help
see page 69
if you suspect heat related issues you could always quickly cool down a suspect compoment with a simple keyboard spray can from the dollarstore... inverted they will cool things quickly to clear up a heat problem an confirm the problem area .. work outside and take care in case of igniting fumes
up to you...suggestion only
Thanks so much for the link!
the vapor separator pump... when running, pull its recirc hose out of its hole in the air silencer up top (it is in the hole, right?) you should easily feel it pulsing air . if ts very weak or nothing, simply remove the hoses to the pump, unscrew it from the separator cover, mark it with a paint pen and take pics so you easily assemble it, and install a new diaphragm. Should pump much stronger, but dont forget to install a new O ring. if anything leaks on the VST tank, or the float is set to shut off to high, you will never get the motor to prime itself properly at WOT it will start sucking air. simply swap the solid hoses for clear ones (port and stbd to each set of manifolds/carbs) and run the motor at WOT for a few minutes. should see NO air bubbles.
Clint W
Thanks so much for this tip CT! I will definitely check it out.
