1995 Johnson 150HP Compression Results
allmuckmojo
Ok, So im selling my boat and had a guy come by and look at it, he did a compression test and said it looked good. I wrote the numbers down, can someone tell me what their professional opinion is, thanks!
1 - 110
2 - 95
3 - 97
4 - 95
5 - 105
6 - 95
I also had a guy contact me and i gave him the results, he said they were too low, any information would help, thanks. I also started her back up for the first time this year and she spat out a bunch of smoke at first, is this normal?
boobie
Re: 1995 Johnson 150HP Compression Results
They don't look that bad to me but a good decarb may help them. Just remember, compression gauges vary and no two are the same.
JB
There is a 20% span. That is too much. She needs a decarb.
Too low? No. Those big V6s were low compression engines. Anything over 80psi is fine.
allmuckmojo
Is it normal to have decarb once a year if not properly taken care of? i just got rebuild last year, could i seafoam it?
JB
Follow the instructions on the can/bottle and Seafoam should do the trick.
