1995 Johnson 200 Vemon Issues
brokerson
ok so i purchased a stratos w a 95 johnson 200 venom.
I took to mechanic and had everything looked over and replaced what needed to be replaced. The day i got it back i put a battery in it that probably should not have gone there. I tried cranking the motor about 20 times. It ran 3 times for about 10 secs. I took boat out of water and the next day bought a cranking battery which i should have done to begin with.
The boat will not turn over at all now. Did i ruin the starter on the motor or is there something else that could be wrong?
Any help will be greatly appreciated
reeldutch
Re: 1995 Johnson 200 Vemon Issues
could be :
- neutral safety switch
- bad starter solenoid
- bad key switch
- blown fuse
- bad starter
not so hard to trouble shoot.
just get a manual
boobie
If you get a manual buy the OEM one. Stay away from Clymer or Seloc. They make good knee pads when your kneeling down working on something.
brokerson
Thanks guys. Im very new to this and agree the manual will be a huge help. Its been so darn cold out I havnt wanted to mess with it. I hear the stripers are starting to chew though so Ive got to get this thing in the water... Happy Fishing
dehydrated
simple test light to see if you got power to the starter or any place else work your way around
jonesg
Theres a small inline fuse located (usually) next to the starter. It might be tucked behind the main harness. If its blown buy a couple for spares.
