1995 Johnson 50/35 Jet Carb/Fuel Pump
Jet35
Model #J50JEO. 7yrs ago had VRO disconnected.So I premix gas/oil.Have'nt had boat out for about 3yrs.Filled 6 gal tank with fresh gas/oil plus 6oz.of Sea Foam.Fired motor up idled good,but would not run wide open.But if I held the choke in at the key motor ran good.Figured I needed carb's rebuilt.Took it to a Mech who rebuilt them.He told me that he found some black rubbery pieces in the carb's and that the fuel pump may need to be replaced.Took boat out after having carb's rebuilt.Motor would idle good,but would not run much faster than about 5mph.Tried pushing choke in at the key,boat would die.Normal speed wide open would be about 30mph.Someone please give me a idea where to start.Which manual should I buy ect.Going to give this a try on my own so I need the help.If the fuel pump does need replacing,do I need the VRO one or is there different one since the VRO has been disconnected?
Thanks in advance.The water calls I must return.....
