Re: 1995 johnson 70hp no spark.
If you "bypass" the kill switch, you will never get a spark. To rule out the kill switch, just disconnect it.
No spark any cylinder, your first step is rule out the kill circuit. Black wire w/yellow tracer, when grounded it short-circuits the powerpack, killing spark. Could be faulty key switch or emergency kill switch, or a wiring fault -- likely somewhere on the powerhead where insulation gets chafed and bare wire touches or arcs to ground.
Easiest to just unplug the big red main wiring harness plug and repeat your spark test by jumping the solenoid. This won't rule out short-circuit in the powerhead wiring, so you'll want to inspect it closely.
Note that if the motor starts with the kill wire disconnected, the only way to shut it off is to manually engage the choke.
