Heywire77
Thread starter- Joined
- Jun 19, 2012
- 101
I just purchased a boat and was told that it was ran hot and shut down and they had it checked and said that one cylinder the rings cam apart and scored the cylinder also . My question is can this block be sleeved , I seen online they sell sleeves that are already to go in and they come with new piston and rings for that one cylinder . My question is does this cylinder have to be bored to put the new sleeve in ? Or would it be cheaper to bore every cylinder and oversized rings ? I'm fixing to pull the motor down this weekend but from what I can see down in the cylinders with the bore scope it only looks like the one cylinder has alittle score in it . I know I just can't afford a couple thousand dollars and here no one does machine work . So I would have to find a place I could send the motor to so they could do the work unless the sleeve just press in and out . I know some 2 stroke motors have sleeves already in them so I didnt know if this one already had one also if it does then that would make it easier ? Also motor is the 2.5 fuel injected 200hp 1995 model . Thanks
