1995 maxum canvas rigging
Jimmymac233
Help!! I have a 95 Maxum 2000SC w/factory canvas. I can't locate the "main Bow". Maxum is no help. I have a part number 51190-A (US Marine 1995). Does anyone know who sells this piece of aluminum tubing bent to factory specs? Help! I want to restore my boat the right way. Jimmy
sdunt
Re: 1995 maxum canvas rigging
Do you have any kind of pattern you could use to make your own? If you can't find materials locally, you might try onlinemetals.com. I have ordered several different sizes of pipe from there for projects. They have a search where you can put in the necessary outside dimension, OD and it will diplay all pipe that meet that measurement.
do you have the other bows? it should be stackable, and most likely about 2" longer than the front bow on each side.
Jimmymac233
tommays
http://www.maxumboatparts.com/
I have a 1995 2000Sc also
Its kind of hit and miss mostly MISS
Islander boat center has a good parts place down at bergin point and if you call with the HIN they will tell you
But at 11 years old i have been on my own there are a LOT of canvas shops in are area that should be able to bend you a new one very easy
Tommays
