1995 Mercury 115 4 cylinder 2 stroke three jaw reverse gear replacement
knf3boat
I have this 115 Mercury that wont lock into reverse. Ser # 0G257156. Tried shift cable adjustment. Wont hold even if shifted by hand at engine linkage.
I pulled the carrier and prop shaft assem. The shift cam, clutch dog and reverse gear are worn bad. Three jaw reverse gear.
I looked up the parts. It shows the three jaw gear NLA. Replacement is six jaw gear set, forward, pinion, reverse. Are there other parts i will need to make this switch other than clutch and shift cam.
Sei gearcase swap says you need to pull powerhead and replace mid section shift shaft.
Is there a Mercury service bullitin on this three jaw to six jaw swap?
Thanks in advance.
carholme
Re: 1995 Mercury 115 4 cylinder 2 stroke three jaw reverse gear replacement
S/n comes up as:
MERCURY - (115 H.P. (1995 ))
Serial No: 0G257156 Model No: 1115412RD
Parts and Service bulletin List for s/n 0G257156:
Search Results - Crowley Marine
See CLUTCH FAILURES - 75 THRU 125
If you do not have the service manual and would like a copy, send me a PM with an email address.
Gerry
knf3boat
Gerry, Thank you. That is what i was looking for. PM sent.
Thank you very much, Ken
