1995 Murcury Force OB Won't Start
Papa Don
I just bought 2 120 HP motors. One starts one<br /> will not. They sat for 2 years. (The one that<br /> won't start) The starter enters the flywheel<br /> but will not turn over the motor,some times it <br /> will but very slowly. It will kill the battery<br /> if i keep tring. It turns over hard with a <br /> wrench. The person i bought them from stoped <br /> running also. He got 3 to 5 for theft.<br /> Can anyone out there help ?<br /><br /> Thanks in advance.<br /> Papa Don
andy6374
Re: 1995 Murcury Force OB Won't Start
So, the same battery can crank one engine fine but not the other...<br /><br />Sounds like the other is partially seized. Spray some penetrating oil down the cylinders and let em' soak, see if this helps.
Papa Don
S.C.P.O Andy<br /><br />How would i go about doing that?<br /><br /> Papa
rickdb1boat
Pull the spark plugs and put a couple of spoonfulls of outboard oil in the holes. Let it sit overnight and see it that improves the turnover. Corrosion may have set in on the cylinder walls.
Papa Don
Thanks Rick<br /> I'll give it a try.<br /> Back at you later.<br /> <br /> Papa
