Hello, I am a new here. I just got my 1995 Stingray 606ZP out of 4-year storage and she does not want to start. It has a new battery, I suspected the starter solenoid so I pulled the starter out and it bench tested fine. The starter signal appears to be the culprit, it is a yellow/red wire. If I jump 12 volts to that solenoid connect it will spin. I measured only 10 or so volts on that yellow /red wire when I turn to Start and it is evidently not able to supply enough current to the solenoid. I don't know what it goes through from the ignition switch, I would assume the neutral safety switch for one. And what is the purple wire going to the other small post on the solenoid, something about a ballast resistor bypass, what is that? And lastly, how do you get to the back of the dash and switch panel? Since it is all fiberglass behind it they must pop out forward right? I was hoping to find a complete schematic of the boat wiring but all I find is generic wiring diagrams.
Thanks, Tom Manson
Rockford, IL
Thanks, Tom Manson
Rockford, IL
