1995 Yamaha 115 Trim Motor Replacement
healey8390
What is the easiest way to do this? Not trying to take the engine off... Looks like I can take the whole "assembly" out by removing the bolts on the side. TIA!!
boscoe99
Either remove the entire T & T assembly from the motor and change the pump motor there, or with a bit of finagling the trim motor can be removed in situ.
Either way, no need to remove the motor from the boat.
healey8390
I got all the bolts out and the assembly won't come out, not sure what I'm doing wrong. I can get to two of the trim motor bolts but I can't get to the bolt in the back corner.
