Re: 1996 112 SPL Evenrude overheating
Bam1,<br /><br />The thermostats on a crossflow V-4 are not easy to change.<br /><br />They are located between the cylinder heads at the bottom of the block on the rear of the engine.<br /><br />If you look between the heads, you will see two hoses going from the heads to the thermostat housing. They are under that housing.<br /><br />It is much easier to get at them if you loosen all the bolts to the lower pan for more clearance.
