Jetfixr
Thread starter- Joined
- Jun 1, 2013
- 31
Ok what next, compression tests all at 130, rebuilt carbs, new plugs, when running its real rough, did the old plug wire off test to see which one is not firing, found #3 not firing, no change when wire is off but it shocked the hell out of me swapped plugs no change put new igniter on cylinder no change swapped wires no change. I need a solution or some ideas I'll go through the lower carb again. Any idea folks? I'm fresh out of thoughts on this one.
Jet
Jet
