1996 130 hp no compression
langer
we have a 1996 v-4 130 hp evenrude that has 1 cy with no compression what should we do?
looking at back end upper left is 0 comp. the other cyls have 135+-?
Daviet
Re: 1996 130 hp no compression
Remove the cylinder head and see what happened.
Boss Hawg
ZERO compression :confused:
Love to see a pic of that cylinder :(
langer
well apparently all is well
we sprayed some wd40 into the cylinder and fired it up and then checked comp with it running and it as well as the others have about 130psi so we lucked out...i hope
