MaggieRose
Thread starter- Joined
- Oct 4, 2007
- 65
Started my engine after rebuilding it over the winter.
I completed all link and synch checks and, with the white/black idle stablizer lead isolated, found the idle timing at 8.5 degrees ATDC. The idle speed of this engine sounds smoother than I have ever heard it in the last 6 years.
I have read on this site, that because of the 10% methenol in gasoline, an additional 2 degrees of retard is recommended beyond the Mercury timing specs.
I am setting up to check the cranking and WOT timing, but the shop manual has a caution that "the maximum timing at cranking speed in neutral to be retarded 3 degrees from specification." My carberated engine has specs of: 0-9 degrees ATDC IDLE, 21 degrees BTDC CRANKING and 19 degrees BTDC WOT.
With the W/B idle stabilizer lead isolated, what should the timing be for CRANKING and WOT on this engine?
HELP!!!
HELP!!!
