1996 150 mariner oil mix ratio
crabshaw
I have a 1996 150 mariner with the oil injection diconnected, last owner mixed his fuel and oil 30 to 1 .
Does this sound about right?
rwunstel
Re: 1996 150 mariner oil mix ratio
50/1 is right and what Mercuy recomends but I use 40/1. 30/1 want hurt your motor, just a little added smoke. Just my .02 worth.
JB
No, crabshaw. The correct mix is 50:1, One pint TC-W3 outboard oil to 6 gallons 87 octane unleaded.
Ought to start smoking less. :)
gss036
You are probably way overdue for a decarb using oil at 30-1. What type of fuel tank do you have?
crabshaw
What do you mean by the fuel tank, the size or what the tank is made of. And what do I have to do to the carbs?
JB
You don't have to do anything to the carburetors, crabshaw.
"Decarb" is short for decarbonizing your engine to "clean out" the cylinders.
I think GSS wants to suggest how to go about decarbonizing your engine. He needs to know the size and type of fuel tank you use to do so.
GeoRXT
How do you disconect the oil injection from this engine? Or a 125 hp
sschefer
Its pretty easy to think that more oil is better but the reality is that a 30:1 mix is not good for your engine. It will decrease the amount of fuel the engine needs for cooling and cause your engine to run lean. The lack of cooling will damage your engine.
Extra lubricant might only be needed during break-in or in a highly modified engine.
The correct mix is 50:1 like's been said. Thats 2.6 ounces per gallon
sschefer
Remove the oil pump, remove the pump gear, put the pump back. Disconnect the rotational sensor, disconnect the alarm module, remove all the hoses, remove the prmary and secondary oil tanks, plug the pressure port on the block. If your fuel pump has the oil check valve on top you need to change the diaphram if it is inline with the fuel line then just remove it and replace the hose with a single piece.
Don't forget to pre-mix your fuel.;)
JB
GeoRXT, you have "hijacked" Crabshaw's thread (and an old thread at that) with a new question.
You have confused sschefer about what/whose question he is replying to.
That is not a good idea. You will get much better response if you simply start a new thread with a new question.
Thanks. :)
Dukedog
He might have hi-jacked it but thats not a good idea. You need tha block off kit that has a "stem" on tha plug. There is a brass bushing in tha block that tha pinion gear rides on. It needs ta have pressure on it ta keep it from possibilty of workin' loose...................
sschefer
Thanks JB, thought I'd throw him a bone since the thread was old. Didn't realize how old it was after I posted. Thanks for chiming in:)
sschefer
I looked at that when the engine was tore down. Not likely to happen.
Dukedog
Not likely but.................if your gonna do, DO IT RIGHT and not take tha chance.......
