1996 200 saltwater s 2
richardr
The boat sat for 3 months and just change water sep filter and put new gas and gas treament stuff in gas tank .now as always it started rite up no problem ,,,, I sprayed carb cleaner in the carbs and ran it for 15 mins or so and put it up to 2000 for a while the engine sounds like it is running on a few cyl. how do i change or clean out high speed jets ( where are they )???
thanks guys i love this site
richardr
99yam40
Re: 1996 200 saltwater s 2
Yes like all carbs there are settings that need to be made. It is best to check where it was before and hope someone has not got it out of adjustment before you.
Hopefully you are not spraying carb cleaner into the carbs while the motor is running. 2 strokes do not like fuel without lubracation, and all the other chemicals do not do good things to the motors internals
cousinabe
Hi guy thanks alot do you have to tune them again like turn themand count the turns and put them back in ???? clean???
there is no adjustment on the high speed jets.
