saltchuckmatt
- Joined
- Jul 19, 2019
- 3,014
First off....I love the vro but this motor didn't come with one. Just picked it up....starts awesome and idles great. 125 on all cylinders. Motor, control box and fuel tank $300Good motors. Just make sure the oil injection has been disconnected. Expensive ignition parts.
Here is the parts breakdown for this motor. No sign of a vro or oil pump.First off that motor came with A VRO from the factory. Second it was a pos 2 pump system that had a high failure rate. Be happy it's gone. The ignition is the big dollar item as lt is crazy expensive. It has a hybrid optical system I believe.
???-----Did you look under fuel system for the mixer unit ?--------Did you look under crankcase to find the oil tank ????-----Not sure what the issue is.----But those all came with an automatic oil mixer from the factory.-----But every one that I have , has had that " mickey mouse" system removed and tossed out.----Every dealer that I know says " take it off off and toss it away as far as you can
So what pumps the oil?It has 2 FUEL PUMPS in the system.-----It does NOT have an oil pump.-----It has an oil mixing unit in the system.
Cool, thanks for the reply. $300 for a power pack is basically the average so nothing there to note. I think it might be a better troller than my 87 30hp but we will see.I have a 2001 Johnson 25hp 3cylinder. Bought it about 10yrs ago. I did have to change the power pack once and it was expensive like 300 I think. Other than that just impeller and plugs. It gets used a couple times a week from may to November. Mostly trolling. I'm pretty sure from 96 to 2001 there all the same Johnson or rudes.
Mine trolls right down. I actually have to give it a little bit of throttle because it's too slow some days. It's on a 14ft lund.Cool, thanks for the reply. $300 for a power pack is basically the average so nothing there to note. I think it might be a better troller than my 87 30hp but we will see.
I have a 16 ft lund that my 30 is on and I am thinking of swapping it out. Do you know if those are both rated at the prop? (HP) again, 87 30hp 96 25hpMine trolls right down. I actually have to give it a little bit of throttle because it's too slow some days. It's on a 14ft lund.
