1996 28 hp gear case compatibility with 1970 20 hp
heypawpaw
Looked at a 1996 28 spl long shaft and it has a split gear case that looks like my 1970 20 hp gear case. Are these interchangeable?
Have you looked at the spline on top of the driveshaft ??----You may find they are different.
heypawpaw
Thanks raceoner, I haven't looked, didn't want to invest in the 28 if not compatible.
Chinewalker
No, they are not. 28 uses heavier gears and bigger diameter driveshaft than the old 20hp unit.
