1996 40HP Merc with no spark - any suggestions?
Cakeater33
Have a 1996 40HP Mercury that's getting no spark from any plugs. Removed the plastic casing over the switchbox and found a red wire from the voltage regulator to the solenoid had grounded out. Reconnected the wire (see attached picture - repaired wire has blue splicing). Still getting no spark. Any suggestions on what may be wrong or what to test next?
Thanks,
Cakeater33
hkeiner
Re: 1996 40HP Merc with no spark - any suggestions?
There are varous possibile reasons for no spark and various tests that can be done to identify the reason. A shop manual for your particular motor would be the best source for such guidance, as it would contain step by step instructions for the various tests. If you don't have a shop manual, the below linked troubleshooting guide may be of some help.
If you don't solve the problem after doing the prescribed troublshooting tests , report back on what you did test and what you found out. This information will help in providing more specific advice. Good luck.
http://dolphinmarineservice.homestead.com/ign5.html
