Re: 1996 5.7l EFI with Bravo 1 overheating immediately.
Now that colon discussion is over, I would like to jump in to the fray. I have a theory on the super quick over heating issue. This is how I read your initial problem: once the alarm sounds, the water temp is very hot. You kill the engine, wait until dash temp drops to normal. Re-start, dash guage jumps after a few seconds.
So, here is my scenario: impeller goes out, water temp goes up, engine shut down. after 10 minutes or so dash guage reads normal, because it is reading the water temp in the senders near vicinity. the rest of water in the block, between cylinders etc. is still over 160. you start the engine, the engine water pump pushes the still hot water up to the temp sender and dash guage says your overheating again. almost immediately. If you keep engine running, in fact, you are overheating again due to impeller not supplying raw water.
Yes?
