Re: 1996 50 hp won't turn over
Kiya,<br />Hold on a second bud....<br /><br />You said:<br />I disconnected all wires from the solenoid. *** OK, good start...<br /><br />No continuity between the two large terminals(no needle deflection). *** That's perfectly normal<br /><br />Hooked power to the signal terminals and heard a solenoid click. **** Thats good= Good coil<br /><br />Took another reading across the two large terminals and had a full needle reflection on the ohm meter. **** That's Good= Internal Contacts Initially Good (should test under starter load) <br /><br />Tested the two large terminals after removing power and no needle reflection. Solenoid no good, Correct????? *** Nope, solenoid sounds like it's operating like it should. Your meter should read an open circuit (no contact)<br /><br />Before we go any further here, I must know if your solenoid has 1 or 2 smaller posts. We already know for sure that the solenoid has 2 large posts (one to the battery, the other to the starter).<br /><br />BTW, don't replace the starter solenoid with an automotive type. Marine solenoids are sealed to prevent internal sparking from igniting any fumes under the hood. The last thing you want or need is to hear the whoomping sound!
