1996 70 hp shift linkage issue for a remote set-up
bently
I have been out a couple of times now and have been having issues with my engine not fully ingauging into reverse. As I move the shifter lever and sounds like it is starting to shift just continues to make the sort of grinding sound. I remove the engine cover to find the lever is not being pushed all the way back into position. The plastic end has a lock nut but is tight and has not moved so I adjusted it and it will work for the day and next time out it acted up again. Is there another adjustment I cannot see that is working loose on me, thanks.
