1996 75hp force exhaust gasket replacememt
caution
Found some unburnt exhaust leaking at the bottom of the port side exhaust plate. Wondering if this is a dificult job to replace the gaskets. Should I use locktite of any kind? Anything I should watch out for before I begin? Any help with this would be appreciated.
jerryjerry05
Re: 1996 75hp force exhaust gasket replacememt
See if you can tighten the bolts holding it in.
Some times changing these gaskets can be rough.A lot of times they will leak worse.
Make sure the mating surfaces are SPOTLESS!!! Use some kind of gasket sealer.OMC/Merc puts out a good sealer.Don't overdo it with the sealer a thin coat will work .J
