1996 75hp force fuel enrichment vavle
caution
Can someone help me with how to test and can it be disassembled? Are the parts to repair still avaiable?
pnwboat
Re: 1996 75hp force fuel enrichment vavle
Fairly easy to test. Disconnect the fuel line that goes between the fuel enrichment solenoid and the motor right where it is attached to the intake. Place the loose end in a small container to catch any fuel. Pull the lanyard off of the "Kill Switch" so the motor doesn't start. Crank the engine and push in on the key to engage the fuel enrichment solenoid. You should see some gas come out. Only time you should see gas come out is when you push in on the ignition key while cranking. If you see gas coming out while cranking and the key NOT pushed in, then the solenoid is stuck open. Sometimes a squirt of carburetor cleaner in the intake and outlet connections on the solenoid will clean any gunk out.
If no gas comes out when you push in on the key while cranking, make sure you have 12 volts at the connector for the enrichment valve when you push in on the key. You don't have to actually crank the motor to test for voltage. Turn the key to ON and push the key. If you have 12 volts, then the solenoid is probably toast. If no 12 volts, then you have a wiring problem. Make sure the grounds are making good contact and that the bullet connectors on the wires between the enrichment valve and wiring harness are making good contact.
New replacements are about $90, used ones run around $20 - $30.
