1996 8 Hp. Evenrude
GasCan II
Is there no way to flush this motor other than in a barrel?
Thanks.
Daviet
Re: 1996 8 Hp. Evenrude
If the lower unit does not have a flush port, you are going to have to run it in a barrel.
What is your model number?
GasCan II
Daviet;
The mod # is EBREDD serial # is 03808996. Also what manual do I order ?
Thanks !
Vic.S
Daviet;
Thanks !
It's a two stroke model. The four strokes can be flushed with muffs ITYWF but not the two strokes
But check the model number more carefully That's an "8", for 8 hp, not a "B"
Also suspect final letter may be "S" not "D" although it is only a manufacturing suffix.
What manual do you want Owners manual or Workshop manual . Former avaialble from http://www.outboardbooks.com/
Cannot help with workshop manual but maybe something of use at http://boatinfo.no/lib/library.html#
GasCan II
Vic.S;
Thanks for the help !
