Darrell W.
Thread starter- Joined
- May 22, 2009
- 13
Comes out of hole and top end okay but if you pull it back to idle, feels like it's running on 3 cylinders and wants to die. Will eventually stall out if you don't give it more gas. Replaced spark plugs and fuelhose/primer bulb, rebuilt fuel pump, and de-carbed engine. The carbs were rebuilt about 2 years ago and they look like they are brand new. I took the idle cover off the top carb and it was perfect - no stoppage at all. I used compressed air to clean out lower carb idle air passages and they seem to be okay also. It ran and idled great one minute and then suddenly it developed this problem. Quick question - if the idle air passages are clear, would another carb rebuild make any difference on idle performance?
