1996 90hp johnson
72INVADER90HP
Ok Heres the Problem, I have a 1996 90hp Johnson that has not been started since last summer. I got it to run and finish the old gas that was in the carbs. Upon attempting to start the motor I noticed that there was what looked like gas or oil coming from a hole that is on the top carb. the only time it came out was while attempting to start it.
jtexas
Re: 1996 90hp johnson
gas shouldn't come out anywhere. can you post a picture of it?
Is she running now?
72INVADER90HP
It is running but not smooth I will send the picture here in a secound
rickdb1boat
You can bet the carbs are clogged up and that's why the gas is coming out. You will need to remove them and clean them out...
jtexas
this is the Picture of the carbs
I use www.photobucket.com it's free & pretty easy, upload your pic then paste the url here between "
" without quotes or spaces
72INVADER90HP
this is the holethat I was talking about
