captlee
Thread starter- Joined
- Aug 22, 2008
- 101
17' proline with a '96 evinrude 90 hp ocean pro. Had my boat out today in 2-3' seas. While making a turn into a big wave I took one on the engine cover. The boat bogged and started to run rough, it would shake violently at 2800 rpms. I brought in to the dock at around 2600, it idled a little rough. Inside the cover had a only a little water towards the back below where the air intakes on the case are. Coils and wires were dry.
When I got home I pulled the plugs, the #4 plug seemed water fouled, had grey/white residue on it like a blown head gasket. Did a compression check, right around 130 on all 4. Cleaned up the plug, ran motor for 10 mins on the muffs around 1800 rpm, plug looked fine, idled better than at the dock. Started motor with #4 plug out, no water coming from cylinder. Could seawater have backed up through the exhaust and flooded the cylinder when it got swamped? Any advice or help would be appreciated, thanks
