Purerock Racing
- Joined
- Sep 26, 2012
- 9
I have an issue with my 1996 E15FREDC outboard. The previous owner said there was no spark and it wouldn't start (I bought it as is). It's got lots of compression and looks brand new. I put in new plugs and see no spark, but the motor did actually fire up twice for 4-5 seconds, then I shut it off, but that's it. I assume the motor has been sitting since the gas that I drained out of the carb. smelled horribly old. Put in a fresh gallon of gas in the tank, the prime bulb was already pretty hard. Still no start again. I then drained the bowl of the carb. again, and pumped up the bulb and I could feel something pass thru and the carb filled up full after about 5-6 squeezes. First pull and it started right away, shut it off and called it a day. I let the motor sit in the garage on the stand for 2 weeks and now the same thing, I can't get it to start at all. Should I pull the carb. and fuel pump out as the first things to clean? This is a 1996 motor that looks and smells like bran new. Even the oil looks like brand new. I bet it was only used a couple of times. How do you test the coil? I see no evidence of gas in the cylinders or on the plugs after pulling the starter 20-30 times with full choke.
