Re: 1996 Force 120 has trouble starting
Yes. Not enough fuel with the gas. My plugs actually carbon foul badly at 1 turn out on the idle mixture screw, I start at one turn out and move it in to find the right setting according to the manual. If you don't have a manual, read the engine FAQs section of this forum and learn about what to do before you do it. Running lean for too long will melt your outboard.
23 is the idle MIXTURE screw. 24 is a spring, it is not a screw.
Idle speed screw is elsewhere on your motor,
as a complete neebie here.. can you define what a "lean Mixture" is exaclty? too much air in mixing w/ gas? or the other way around?
also just to confirm the screws that you are referring to are parts 23+24 on the following site::
http://www.dougrussell.com/partscatalog/components/index.cfm?fuseaction=viewparts&colid=06&coldesc=120%20H%2EP%2E%20%281996%29&index=2009&block=6&BlockNumberList=10,6,1,0,13,11,12,17,14,25,8,19,21,20,22,18,2,3,28,23,24,7,5,4,15,26,27,9,16
