gutterman65
Thread starter- Joined
- Jun 27, 2025
- 4
First and foremost thanks for reading and any help ypu can provide. Hello, I'm new to the forum, I have a 1996 force 120 2 stroke outboard i need assistance in sourcing the proper lower for replacement. After purchasing under the pretense of needing a simple cable adjustment I've since realized the lower is toast. There are no discernable gears after removing the unit and manually turning the shifter rod. I'm looking to just replace the lower completely insteadof rebuilding because parts look hard to source and expensive where you can find them. I've found reputable vendors selling them and am ready to purchase. My issue is that the internet research I've done says that the 1996 120 should have the 3 dog reverse clutch for that year model but when I disassembled it my current unit installed is a 6 dog reverse clutch, so I'm thinking the previous owner replaced the lower with a unit off a newer year force outboard. So my question is should a 6 dog reverse clutch lower from a 1999 force 120 work on my 1996 force 120 or is the wrong year model lower the reason the current one gave out, I've found a replacement that seems reasonably priced and the only thing that's kept me from purchasing is I'd like 100% certainty it will work. Again, thanks for any help and advice, stay safe out there on the water, I can't wait to fix this thing and join y'all!
