the bricker
Thread starter- Joined
- Feb 21, 2010
- 1
my glastron has some rot in the floor around the in floor storage, how would I go about fixing this?
^^^^ gandk, I think you posted this to the wrong thread.....
hi there great post and thinking of doing a very similar job my self soon to a 16ft fletcher with patches of rot.
I noticed you used solid wood for the stringers and box around your tank. i have a similar set up in my ski locker which is central and the tanks are small removable ones. Is it ok to use solid wood? most i have seen seen to use sheet ly cut to shape but i guess it its totally glassed in does this matter at all? what type of solid wood did you use?
Also i like the idea of drain holes in each stringer etc to allow water into the bilge, anyone know if its common that boats are designed without this so it can just fill up with no drain? Can i have sealed foam filled compartments under the deck instead? i cant find any drainage in mine at all but i havn't removed the floor yet.
